Golf Cart Wizard: I need your expertise on my problem. I understand that the MCOR4 will eliminate the V-Glide only. I took the V-Glide off and examined it. It was very clean and shiny on all brass strips. I did adjust it, so it was tighter and perfectly aligned. It didn't make any difference. It still goes to half speed when you first push the pedal down. Apparently, the V-glide is bad. Replacement V-Glide is between $350-$500 dollars.
I have a few questions:
1. Will the MCOR4 work on my 36-Volt Resistor Wire Cart?
2. I do not have a hole in the frame where the new MCOR4 controller mounts.
3. Will the linkage have to be modified?
4. I have no clue how to wire it. (My old V-Glide has 4 wires coming out of it).
When I get to the point of wiring, will you help me?
Thank you..............Ron
