94 club car help with micro switch
tcrowe3
I need some help I have a gas 94 club car when you press the gas nothing happens if you hold the gas and press the bottom micro switch in the engine will turn over then release the micro switch with the gas still in the cart will take off but the accelerator is real touchy I have changed both micro switches still does the same thing...
shadowman
sounds like something isn,t adjusted right.....if your talking about the micro in the black box than put the cart in maintence mode and work the pedal and watch to see if its activating the micro switch......sounds like you have an adjustment issue...........................
