94 CC Hard to start
yelilly
I have a 94 CC that is getting hard to start, you press on the throttle and it will crank. You have to let off the accelerator push again and it will start, use to be it would start after 1 time now it will take 3 or 4 times to start. Any help would be appreciated.
Thanks Earl
It's possible that you may only need to adjust the butterfly on the carb. also check to make sure that the choke cable is operating properly. lots of possibilities may need a good tune up and carb. cleaning also check linkage on throttle. :checkered:
