93 speed problem?
Steve
Another problem with this 93 Ez-Go. checked the wiring and I think it is correct. Speed is 9.3mph in reverse and only 5.6mph in foward (GPS). Yes the batteries were down and charging now, but should not the speed be the same or faster in Foward? Also the F/R switch handle seems to be backward. Foward is top of handle to the right but is to the left on a 95 I can look at.
You can swap the (A-1, A2) or (S-1, S-2) cable connections at the motor or at the forward and reverse switch to fix the back-wards F&R switch. Theres a wiring diagram for your cart in the ezgo resource forum here if you want to see which cables need to be swapped.
Steve
OK, switched the two wires on the F/R switch and fixed both problems, handle looks to be in correct position and it now goes faster in foward than reverse as I guess it should.
Thanks so very much for the help.
No problem, glad to hear you got it fixed...
