The saga continues. I said the heck with it & pulled the head off, and I put some gas in the intake to look for seepage. Sure enough I had a valve not quite seating good enough. I lapped the valve again, checked it again, and put it back together. I set the valves at .006 and took a test ride. It's running pretty good, no exhaust smoke, and it will finally go up an incline.
I don't have any missing, or popping back through the carb, but I do have a little gas still spraying at the air cleaner. I took a look at it running with the air cleaner out. I'm thinking the carb needs to be rebuilt. I took it off & cleaned it real good awhile back, but I'm thinking this is the final leg of the journey that I need to take. OR it needs to be adjusted, and that my friends is where you come in. What is the best way to adjust these carbs, and what it a good starting set point. I know nothing about these carbs. I would be greatful for any help you can throw my way. By the way all of you guys have been a great help to me with this project,
Thanks to all.
