Welcome to the forum...
At 35.6 volts the batteries are dead. Try checking the voltage at the receptacle with the go pedal pressed and see how low it drops. Check the individual battery voltages and post your numbers. Check all your cable connections. Make sure the plates aren't exposed and add distilled water if needed. Then let them charge until the charger shuts off...
