91' EZGO no go!
chipmanw
Good afternoon. My 91' EZGO simply stopped in the driveway. Batts are good and charged. Solenoid clicks when throttle depressed in both forward and reverse. Shold my first step be the F/R switch, solenoid or ???
Thanks so much in advance for your kind input.
B.C.
Poway, CA
Is it a resistor coil cart or controller?
Check ALL the cable connections. If the cables check out ok try jumping the two large posts on the solenoid. Then check the contacts in the forward and reverse switch...
