91 Club Car Won't Run Just Clicks
Papaw
Our 91 Club Car just clicks when you mash the pedal but won't run. We were driving, stopped, and since then it won't go. I checked the terminals and eveything seems clean and tight. Don't know if it matters but it seemed to be running faster than normal when this happened.
Welcome to the forum
Did you check ALL of the 6 guage cable connections (not just the battery connections). What is your total battery pack voltage? Is this a resistor or controller cart?
Yep I checked all the terminals. It has resistors, as a matter of fact the first one from the F/R switch was just replaced.
Use 6 gauge or heavier wire to jump the 2 large posts on the solenoid. Its best to make the final connection away from the solenoid so you don't mess up the threads. You can use jumper cables, connect cables to the large studs then clap the cables together. You'll get sparks when you connect the 2 jumper cables togther.
I was starting to consider the horse, but finally found a resistor that was giving me all my problems. I appreciate the help - just thinking it could be fixed kept me trying. Thanks. This forum is great for people like me.
Any one have a horse for sale? I need one. The amish can hunt with guns out of a buggie up here , it is not a moterised vehicle. They come down the road during deer season in a wagon with loaded guns shooting anything that moves.
So was the resistor on the solenoid bad? I have the same intermittent problem. Happens more when it is wet out.
