deerhunter
Hi, new to the site and to golf carts. I bought a 91 ezgo put new batteries in it. It ran good in reverse but in forward it would only run if the pedal was slightly pressed. Then it stopped completely. 37.8 pack volts. I can hear the solenoid clicking (just once not all the time). On the batt. side of the solenoid it has 37.8 volts and controller side it has 21 until you press the pedal then it goes to 37.8. The orange wire coming from the micro switch on the pedal assembly has 37.8 but, in between the orange and black wire which goes to the controller is a diode or resistor (orange wire side has 37.8 black wire side has nothing). Also, I have checked the potentiometer a the pedal and it has 0-5000 ohms as it should. Am I right to think that the diode is the problem. Don't know where to go from here. Any help would be appreciated. Thanks, Brandon
