90 Par Car No Spark
Damien
Just curious if anyone has an idea where to start next. On the coil itself I have constant 12 volts to the positive side and negative side. Tried the old ignition and points and plate with a new coil but it’s always 12 volts on the negative side and have no spark. Any help would be appreciated
cartmaster
If you have voltage on both sides of the coil, your problem is likely to be no negative pulse from the points. You need to investigate that side of the circuit. Make sure your points gap is correct and the points are opening and closing correctly. I don't know your carts setup, but it should be fairly simple to find the fault. Could be just a broken wire?
