89 ezego 2 stroke
ford
i just rebuilt the engine because of no compression and now i am getting very little or no fuel from the tank fuel pump looked ok. does anybody out there have any other ideas. this carts is really starting to piss me off!!!!!!!!!!!
so your saying that you had good fuel flow before the rebuild? did you install new crank seals.
ford
yes i put new crank bearings seals piston rings and jug it is all new. it ran wen i first got it done but not at full speed so i checked compression again and it was at 120 and befor the rebuild it was 50 so i really don't no what is going on
You have a leak somewhere check under the gasket for the fuel pump to start.
how is the cylinder bore ?new rebored did you mike it or hone and add rings ?
just trying to get some ideas on what could cause it .
rusty s
ford
it is a new cylinder. I put a new fuel pump on tonight and i got fuel but i think the crank case is full of fuel now which usually means torn diaphram but they looked good could the flow be marked wrong on the pump or does it matter really getting frusterated!!!!!!!!!!!!!!!!
