cart quits 5min after running, somtimes will idle but no rpms. if you let cool down it will go again. where is rpm limiter and if you disconnect will the cart still run. also when it quits there is no spark with brand new plug. just trying to figure out if it is the ignitor, coil, rev limiter or somthing else. there is no fuel problem.
