87 elecrtic Club car not working
neverrideahonda
Was working fine but does not seem to be getting power to motor. It did this a while back but started working after 2-3 minutes. When you put it in gear and hit the gas it just makes a small click. IN nuetral it makes no sound. WHere should I start. The batteries are fully charged.
Welcome to the forum...
What's your battery pack voltage?
Check ALL the cables and make sure all cable connections are clean and tight.
JRay
Thats a 5 solenoid cart. if all the wiring and batt. check out, i would jack it up and jump the first solenoid. Pretty common for the master solenoid to go on those carts.
neverrideahonda
Where are the solenoids located? I remeber when I bought it they gave me a new one to install. You have to jack it up to get to them?
JRay
Jack it up so the wheels can spin and not run over something. the solenoids are behind the batt in the rear. Jump the first solenoid, drivers side, press the go pedal see if it runs. If it does replace that one.
