I've been having a frustrating issue with my 1986 EZGO Marathon cart. I replaced all the oil and fuel Ines, removed and cleaned the carb, changed the air filter and spark plugs. Then I proceeded to confirm there is spark when the pedal is pressed. The strange issue is with the spark plug removed everything moves with no indication of any problems. The generator, clutch and fly wheel are all moving freely with no abnormal sounds being heard, and fuel is being pumped to the carb. When I put the spark plug back in, everything stops or rotates in a surge like motion and doesn't pick up enough rotational speed to fire. I'm really at a loss and can't get any help where I'm at, as the nearest cart repair shop is two hours away.
Any ideas or suggestions would be greatly appreciated. Thanks.
