shifty8913
Put the new carburetor on and it fired up and runs pretty good. Did not change any linkage adjustments.
What is the best way to know the carb is set correctly?
Also can anyone direct me to a throttle linkage diagram for the 86 DS?
I think I might be missing a grommet or something aroung the nut that holds on the governor rod connector arm piece where the throttle linkage rod also connects.
It appears to have some sloppy play in it?
