Hi Grizz
I did find out, that s/g will work.
Sorry to hear about that. Sometimes it is really strange how things like that happen. The funny thought is... it probably wouldn't have broke that day IF you still had it.... most likely the day after
I would also suggest checking the mounting brackets for the s/g, including the pinch bracket, and engine mounting bolts. The s/g housing usually breaks from either a manufacturing flaw (can take a long time) or unusually high stress. Stress focuses on the weakest point, and for those engines it is the s/g assy. Most common is for the pinch bracket to break, but mounts and housings do break from time to time. So just check those over real quick for any cracks, and make sure all the engine mounting bolts are tight. That will keep you out of trouble
