83 g1 problems
wickednavi
just did new rings and seals got it all done runs great till it gets hot then it doesnt run well unless i pull off the air cleaner hose and it seems to be getting to much gas any help would be appreciated
djlan99
Check the diaphragm in the fuel pump. to do this pull off the hose to the crankcase and you will see gas in the hose.
Crimp the gas line to the carb and see if that helps. ( engine will run on the gas in the bottom of the crankcase and clear up then stall out).
I would start there.
Did you check the air filter? If it runs with the air filter hose off check for the mouse nest!
