'83 ez go 2-stroke
racerjim0
I took the cart dragracing over the weekend and was having some starting problems when all of the sudden I felt something let go. A visual inspection tells me that something in the rear end broke. The govenor pulley( probably not the right term) rotates, but thats it. I changed the oil in the rearend a few monthes ago and everything in there looked amazingly good, almost new. I can't seem to find a diagram of rearend to help be see how the govenor is attached to the rearend. Hopefully its just a bolt or roll pin, you know --cheap. Any ideas??
BadToTheBone
Moderator
So the cart doesnt move at all? Do both clutches spin when you try to drive the cart? Where is the "governor pulley" located? Can you post a picture?
racerjim0
Yes both pulleys spin but thats it, no go. The govenor pulley I'm referring to is the pulley attached to the rear chunk. I sure do wish I could find a service manual for an 83 but I'm not paying $60 cuz I'm cheap and poor.
