I have a '76 model D Harley.
It will run up to full RPM. But a few seconds later, it boggs down like it has lost all fuel flow. Pull the choke out half way and it picks RPM back up. Then a few seconds later it boggs down again.
I have checked the point gap about a dozen times. It's set at .022.
I have checked the timing about a dozen times. It's dead on. Both forward and reverse.
I have checked the spark plug about a dozen times.
I have replaced the fuel filter and all the fuel lines.
I rebuilt the carb (only once). I have reopened the carb and adjusted the inlet control lever properly.
I have checked for vacuum loss around the crankcase. I have checked for vacuum loss all along the side of the carb. No RPM increase or loss while doing this.
I sprayed carb cleaner in the air intake while engine running and starts to bog down. RPMs immediately increased.
I still have the bogging down problem. Anyone have any ideas? Oh yeah. I have good fuel in it.
