oldcartfart
hi' I have a question about cc 48v motor/ controller. I have a CC frame rolling chassis. it has the 48v motor and rearend in it and a bad controller. He bought this to replace an ez-go 3 wheeler with a bad rearend. and to put a 57 chevy body on.now this is my snafu he wants me to do. which i will if it will work. He wants me to pull all the electrics out of the 36 volt Ez-go and old school it in the 99 CC.
i just did this with a 36 volt hyundia cart that fried the controller. the motor was fine and when i was done it all worked out good.
but it was the same voltage. now he wants to go with 36 volt electrics to a 48 volt motor . I do not know if the motor will run as it should due to the 12 less volts?also the i dont know if there is a difference in the motors. controller setup verses resistor. I do know that he plans on using it as a 36 volt cart as he only has the charger for the Ez-go but the twist to that is he has 6-- 8 volt batteries that came with the chassis fully charged ( he charged them with his brothers 48 volt charger)they are about 32 to 34 volt across the pack and he wants to use these in his cart. Do you get the idea of my confussion in all this
I need help to figure if it will all work out. i think the batteries will as long as he charges them with the 48 volt charger but i dont know if the 36 volt to 48 volt will work. how can i check the motor to see if it will work with 36 volt resistor setup? I really might be in over my head on this one but the 57 chevy body is cool and i want to see it rolling. thanks for any help i can get on this idea. Old Cart Fart
