48v EMC Cart, Curtis 1268-5403 Controller Code 34
Hi all, dramas again. Little while back I replaced the brushes & holder on an xq3.8 motor. Has been going great til today. Just started cutting in and out. Fault code registered 3-4. All new batteries and cables, can’t find any loose connections. Wondering if someone can give me a good place to start the diagnosing. Thanks as always.
Okay so I find that 34 means field winding fault - loose / open. I’m guessing this is the do with the f1 & f2 terminals on the motor. All connections are tight, is there a test I can perform with a multimeter.
did you use a back up wrench when you loosened and tightened the motor connections ?
if not, you may have twisted a field connection wire inside the motor
place the T/R switch in Tow
disconnect the battery minus
remove the F1 and F2 connectors from the controller
Ohm between the two wires you should see between 1 and 2 ohms
if not check again at the motor
if it still reads bad, the motor is likely bad
any good motor repair shop should be able to fix it
if the motor reads good
check the cables carefully, sometimes the connector on the end of the cable does not have a good connection
Sorry for the delay response, been unwell. Motor tested okay. I have purchased new
wiring and eyelets. Nearly sure it’s what’s letting me down.
Success!!! So far!!! New wiring installed and it’s off and running. It hasn’t given up after a few hours of use. Thank you Jeff & Zman. The guidance you guys give allows me to be confident in tackling these dramas. I’d buy you a beer but the freight would be a killer. If ever your in Queensland, Australia be sure to let me know.
You Are Welcome !!
