48v Disaster?
Jimbo66
Hello from Dallas, Texas.
I have two commercial properties (self storage facilities) each one having a golf cart. Cart 1 (not an ezgo) began to exhibit low power along with very shallow charge. I was able to determine one battery had a dead cell. I know… I would have replaced all batts, but the dealer only had one in stock.
So one new battery later that cart returned to service. Shortly afterwards, Cart 2 (2000 ezgo non pds) showed signs of aging batteries so without thinking it thru, I purchased six of the same batteries as the one for cart 1. NAPA 8148 which are 8v. Now cart 2 does nothing more than click the solenoid. Apparently the ezgo takes 6v batts, but I put 8v batts in it.
Question is: should the ezgo work at all with that voltage pack, 48 vs 36?
If so, will it be okay to operate or would it cause more trouble?
NO Click you might have fried the solenoid. Try removing one battery that will bring you down to 40 volts. See if you get your click. I hope you did not fry your 36 v stock controller. That would be expensive to replace. See if you can get a used or rebuilt one maybe on Facebook Marketplace.
What motor are you using in cart? Did you upgrade to one that can handle a 48 v supply?
