48 volt help
Gabbyttrop
i replaced a few cable ends with out switching the switch to tow mode , saw no sparks when doing so , now rev. buzzer and cart will not work . Cables are hooked back up right . Did i fry the controller, have cked the fuse at plug in thanks
If the fuse is good and you're sure you have the cables hooked up correctly you may have blown the controller. Double check your wiring on the batteries.
