Will a 36 volt motor work on my 48 volt regen cart? I put it on and the cart wanted to go at first, then nothing. I don't hear the solenoid click anymore.
Hi HRC, real weird now there's 50.7 volts at the solenoid all the time its in the tow position, switch to run and it goes to 49.6. There's always voltage whether the key/pedal is off or not. This just started when I got back in town today.
there is a way to test the controller but its so detailed you need the service manual to do it........did you try and disconnect the reagan braking to see if that makes a difference? i have a feeling you smoked the controller but i,m not 100% certain.....................................
Tried disconnecting the regen but it didn't make any difference. I've accepted the fact the controller is toast. Plan on changing over to series and run the 36 volt motor.
Is there anything that can be done with these controllers such as a rebuild? I have 2 broken ones and would hate to toss them if rebuilding is a cost effective option.
