Yeah, sounds like someone has been in there and done some finagling. That orange wire that goes to nothing in the dash was your oem key switch power, someone has installed that brown wire directly from the battery is what has happened. Really the key switch should be wired (orange wire) from the solenoid positive post, same post that the main battery goes too. When you turn on the key it will send power down to the pedal switch. When the pedal switch is actuated, it will send power to the control side of the solenoid. There really should be a micro switch on the directional control that the pedal switch would run to first.... before the solenoid. But all this does is trigger the reverse buzzer. It is a very common thing where people will just eliminate the reverse buzzer micro switch circuit to get rid of the reverse buzzer. So, when that happens the pedal switch output just goes directly to the control side of the solenoid.
