2016 Yamaha Drive: tire size question
rudiskey
I have the 10" now, but want to add larger tires. I dont want to lift the cart, so need to know what is largest I can go without lifting. Thank you!
dirtysouth
If ya have a rear seat, you may have rubbing on back end when loaded. Otherwise you can run most any low pro tire wheel combo. The drive has a lot of front wheel well clearance and the rear can be corrected with a little tweaking.
Zman
I sell low profile tires on 14 inch custom wheels all the time, they fit perfect on the drive.
rudiskey
Thanks All!
Hi dirtysouth- so sounds like I can try the 14" rims with low pro tires. I do have a back seat, so what kind of tweaks are you talking about if there is some rubbing? To fender?
Thanks!
Ron
