2010 Club Car Precedent starts/stops
MorrisD
When driving the cart, it stopped and then would only move a few feet. I've replaced the solenoid and MCOR. I've tried bypassing the OBC , still the same problem. I've tested some of the wires on the controller and they check out OK. The battery pack is around 44 volts. When I put the charger on and its in run mode I get a continuous buzzer. In tow mode the buzzer is off. Any suggestions for why it won't run?
Notsoslim
Well-Known Member
Sounds like time for batteries. At 44 volts your batteries are at less than 10%. See link to chart below
MorrisD
It was the batteries. I was just surprised that it was running OK going down the road and it just failed. The pack charge showed 44+ volts . I tested it later under load and it dropped to 20 to 30.
