Sorry to say (2) replacement sensors did not fix the problem. After knocking my head against the wall several times I called in the local service tech guru who tells me he's never replaced a throttle sensor in many, many years. After testing the motor, disassembling & cleaning the armature and brushes, he concludes there has to be a short in the controller. But the only way to confirm that would be replacing it at a hefty price and, of course, that electronic part wouldn't be returnable if it didn't fix the cart. So could 2 stuck brushes and a dirty armature have shorted the controller? Also can that be tested?
OR (& what bugs me) is according to my Yamaha Repair Manual, ohm readings on 2 terminals (blue-black) of the sensor should be 5k- I get 2k, then it immediately jumps to 25k. On the other side (orange-black) is supposed to be 0-150 and increase to 5k with accelerator fully depressed. I get 34k steady and no change. (Resistance between the blue & red terminals is 325 ohms both ways). It's the same on the original sensor and the 2 new after market, non-branded, replacements. I've tried reversing the +/- leads for the diode which I assume is in the circuit. Well, I'd think even if sensor is off spec it should show a change as the pedal is depressed, which makes me reluctant to buy a controller.
Your further input would be greatly appreciated.
