2008 EzGo MPT 1200
KOZ45
Here's my 2008 MPT 1200
Multi Purpose Truck?
6" Jake's lift, front winch, rear 2" hitch, front LED light bar, 23 x 10 - 12 tires, electric hoist bed
I believe it has the 350cc, twin cylinder, 4 cycle Fugi-Robin motor?
I would also like to get some whel spacers for the rear axle, to more closely match front track width on the front end
KOZ45
Would also like to add a gas gauge
I see there's already a float in the tank
Wireless bluetooth speaker and Noco Genius 2 trickle charger ordered
KOZ45
I ordered a new air filter, Donaldson P822686.....which looks like a better direct replacement for the 28463G01
I am also going to pull the two spark plugs this morning and order new plugs
I'll change the oil and oil filter this winter
Is there a chart showing all the zerk fitting locations? I see two right away, on the Jake's lift spindle arms
KOZ45
Well I don't think I have a 2008
From what I have read, all 2008 models would have the Kawasaki 401cc
Varying results online for 2006 and newer MPT 120p carts with the Robin EH35C:
25523G5 , FR2A-D
72867G01 , BPR5ES
25523G3 , BPR4ES
guitarman
Be careful when you tilt the seat with that lever. It’s high enough to interfere with the seat when it is in neutral and the seat is tilted all the way forward.
KOZ45
no worries......even in the vertical neutral position and the seat tilted all the way forward, it touches the cushion but doesn't do any harm
KOZ45
FR2A-D plugs are in the motor now, from the PO
I bought the BPR4ES to replace them with
25523G5 , FR2A-D
ISO Height
5/8" hex
72867G01 , BPR5ES
JIS Height
13/16" Hex
25523G3 , BPR4ES
ISO Height
13/16" hex
ISO is 50.5 mm
JIS is 53 mm
New fuel filter and Donaldson air filter were also installed. I also removed the air supply hose and washed out all the dirt and let it air dry overnight
Next up I plan to flush and fill the oil
New oil filter and gasket already ordered
What weight oil??
KOZ45
New plugs, new fuel filter and new air filter installed
It's running great
KOZ45
Just finished an engine swap with the VC cradle and billet plate, new 47" belt, CVTECH clutch and a Briggs 570cc engine
Added LED headlights, LED parking bulbs, and LED underbody light kit
