sniper2478
Hello all, I am new to the forum and to Gof Carts. I just purchased a refurbished 2008 EZ-GO TXT 36 Volt with new batteries. This cart came with a brand new Lester 36 Volt High Frequency Onboard Charger. It wasn't till after purchasing this cart that I found this forum and that onboard chargers are not the best option, well its a little late for that now. My issue is that the Charge Complete light remains lit after charging is complete. This isnt much of a problem until I am ready to charge it again, then I am forced to remove the positive side cable that supplies power to the charger from the battery to re-set the charger. Now there is no switch inline to disconnect power to the charger when not in use. Should I install one? Would this solve my issue? I would greatly appreciate any help. I know this is an automatic charger, but I dont think there would be much of an issue if it was re-set each time. Also just for more info I do have a state of charge meter that is fairly accurate. Thanks
