2006 g23a
trialsguy
Every so often the carb will flood out causing the cart to stall. I have to pull the inlet off then blow compressed air through the overflow tube and it usually helps it for a while but today it consistently kept flooding out. Is there something I should look for or check when I pull the carb off?
Thanks
trialsguy
Yeah what I was thinking but I wanted to put it out there incase somebody had ran across something different. Dang thing might go for days without a issue then like now I can clear it, then right away it starts flooding again.
Thanks
