TripleFever
I am new to the site and appreciate any feedback that anyone can provide.
First the background. I am installing an aftermarket headlight, tail light, brake light, signal light kit on a 2006 E-Z-GO gas golf cart and it comes with a momentary brake light switch that you have to drill the brake pedal to install it through. Problem is, unless you have your foot over top of the switch on the left side of the pedal the brake lights will not be activated.
I looked at a 2006 E-Z-GO electric golf cart and it had a factory floating lower pedal cover and a switch mounted on the underside of the pedal which also picked up the parking brake section to shut the brake lights off when set. I would like to have a clean system that works no matter where my foot is positioned, which is usually on the right side of the pedal.
Now does anybody know if it is possible to retro fit an electric brake pedal assembly with the brake light switch onto a gas cart? It looks almost exactly the same at a glance.
Also, if possible then where can I purchase these components? Are there any cart wrecking yards out there that these parts can be bought from?
Thanks in advance!
Thanks in advance!
