2005 yamaha with rear seat, lifted, steering Q
shrentner
Cart is fine with two people, but when you add two to the rear seat it wanders badly at higher speed. 14.5 MPH. Now I know this puts almost all the weight on the rear axel with not much left for the front, but is there anything I can do to improve this condition?? Short of leaving two people home. Would a change to TOE make a difference, currently it is set to factory specs.
Thanks
JAMES
I'd check the toe first but you will probably need to go with heavier springs on the back to correct the problem.
