2005 EZGO TXT Gas Golf Cart Free Wheeling Like It's In Neutral
ftfixer
hey guys need some help with a 2005 ezgo txt my problem is that the drive and secondary clutch will both turn the shaft turns from the clutch to diff. but it seems to be free wheeling as though it is in neutral. wondering if it may be the cable adjustment or something more serious.cart is used at the mill i work at and only had a couple of minutes to check it out today but would sure like to get it running as soon as possible it belongs to the boss.
divot61
make sure the cable is moving the lever on the rear end, make sure it engages the drive axle, and check to see if you spun a hub on the drivers side rear, thats the side it useally happends to, do you hear a grinding noise when you press on the gas? it maybe a spun hub and hopefully it isnt the differential, let us know what you find out
ftfixer
hey divot61 you were dead on spun the hub on right side. the splines on the axle look to be ok i ordered another hub today. the boss will be so glad he was thinking the diff. was toast but i realy didn't think there were any major problems. i appreciate the help i'll know next time i learn something new almost everyday on this forum.
