The batteries are new, they need to be charged each time you use the cart.
It will take about 25 charge cycles before these reach their full potential.
The cart should go at least 12-13mph on the flats.
What is the total pack voltage? It should be around 50.9v
If it is not, check your battery wiring to see that it is correct, you may have one reversed.
