2003 ez go golfcart 4 cycle engine
codymarsh
anyone have a solution for my problem. On my 2003 ezgo 4 cycle engine the oil is being sucked into the air box.
Welcome
most times the rings get soft which allows pressure to build up in the crankcase, i would start by checking the compression. that will give you a good idea of what your working with
ryanaz
DirtySouth, what is the cut off of the oil on a lifted cart? Cuz I too am leaking oil, and it seemed to have gotten worse after putting oil in it. I left it about an 1/8-1/4" below the full mark. I am in the infant stages of troubleshooting it, but it appears to be coming from the rightside (passenger side) of the crankcase towards the bottom.
