usdave
Hi everyone,
I have a 2001 EZGO TXT (Customized and purchased in 2003). Our cart has always worked fine and worked fine the last time I used it before letting is sit. It sat without charging for over a year. When I went to charge it recently the positive terminals on all the batteries were swollen so I got all new batteries and installed them. I took pictures of all the connections and I am sure everything is hooked up the way it was. The cart charges. When I turn on the key and put it in F or R I get a reading on the battery meter of a full charge. I have 37V across the 6 batteries. When I press the pedal, there is a click from underneath the floorboard and the controller LED blinks green 4 times, then illuminates solid green...and when the pedal is fully depressed the LED turns yellow. According to the Alltrax AXE series manual, this indicates that the controller is setup for EZGO ITS and has no errors. I had a new FNR switch installed a few years ago. I have a spare solenoid that I also tried, but that did not change the outcome. The other parts are ~20 years old.
Thanks in advance for any help and I am happy to go gather more data if needed. I have a multimeter and I know how to use it.
-Dave
-Dave
