Help! How do you remove the speed controller from the motor end cap after the snap ring is removed?
O orielman New Member Oct 22, 2008 #1 Help! How do you remove the speed controller from the motor end cap after the snap ring is removed?
HotRodCarts Cartaholic Oct 22, 2008 #2 The speed sensor should pull right out after the snap ring is removed. Grab the wires and give it a wiggle.
