2001 EZGO Gas Golf Cart Ignition Switch Wiring
Silver Eagle
On the 2001 EZGO gas golf cart ignition switch wiring what color wire is used for the ignition? I want to put a two post switch somewhere on the cart to bypass the original ignition switch. And in it's place I want to hook up a loud horn so if someone were to try to take my cart the horn will blow when the key is turned to start the cart. Any Ideas.?
johnered66
I would move to a nicer neighborhood....just kidding....I am following this post as well...my wiring for the lights on my cart are a mess and I am in the process of trying to clean it up...and I have no horn.
Silver Eagle
The ignition is just a on and off switch on a golf cart. Only one wire is hot until you turn the switch on. I found a guy in California that sells EZGO ignition switches that use a different key. So if some one were to use the standard key nothing will happen. I forgot his mane but he's on this forum and I'm sure he will jump in with the information that you will need. And they were cheap. :D
