2001 Ezgo Electric "Casper"
Pimp Daddy
Here is a good shot of the double Jake's lift and front suspension
johnny9
dam,it gets nicer w/every pic i see..i tryed makeing the front bumper you have and wasted a little bit of material since i was bending it by hand and heat..i think i will just buy one.
probally cheaper in the long run,haha,john
Pimp Daddy
John,
Thanks for the flowers! I know the solid would be stronger for the brush guard,but you could get either aluminum or stainless tubing and be able to bend with a hand bender.Don't give up, still waiting to see the finished product. I guess the deal on the jeep didn't go? Still belive the cart would have more fun factor!! Keep up the good work
Pimp Daddy
Hey Guys,
Been away for a while.Work has picked up some and the good weather has been keeping me busy.Finally got the yellow neon installed on Memorial Day.That is the bad thing about the cart being 5 hours away,don't have time to do a lot of things to it.
StreetGlide
Hello,
I agree with John and HRC!
Look "cool" to me! (or in proper terms this day and time "they're BAD!", no, that's old too. I know ... "they're SICK"!)
I other words, I like them a lot.
Often wondered about power, how many watts total?
Again, "really SICK", man!
Pimp Daddy
Thanks LnS,
The power draw of neon is really low compaired to the light delivered.I copied this off the Street Glow website.
The switches are usually 5, 10, or 15 amps. The 20" accent tubes are about half an amp and of course the 15" and 10" accent tubes are a bit less. The sg201 (Gold Series) is 4 amp and the BlueLine tubes are about .750 of an amp (3/4). The sg201 (Gold Series) transformer is 4 amps. It all depends on what your linking up. As with StreetGlow products, they are pretty much interchangeable as far as linking methods go. Please contact us if you need anymore help and we'll be glad to answer your specific questions.
By the way You should check out the light kits for Harleys.
Pimp Daddy
Been doing some research on running mud tires on sand. The Dirt Devils would dig down upon take off. Read somewhere that you could reverse the tire rotation,switch the rights and lefts on front and back, and they would "float". Not only do they float on sand the ride is greatly inproved on asphalt also. Anyone running mud lugs should try this.
JRay
I should give that a try, my swamp fox tires are getting on my nerves. Must be getting old. time for some smooth riding tires.
Pimp Daddy
JRay,
Try it, it really helped. The tires thumped so bad at low speeds the shorty windshield shook violently. Now it is close to the Duro Deserts I was running.
Pimp Daddy
While on the Street Glow Website noticed they had a forum.It had been down for a while, but was back up and stumbling.It makes for interestig reading.
StreetGlide
Your right, it makes for interestig reading (AND looking)! Thanks for sharing!
(ref a past post, I did check out lights for the "scooter". I had looked and discussed them with folks from Street Glow at a past rally)
Pimp Daddy
John,
THANKS!! Had a blast riding around with the music at a much louder level that I usually ALLOWED to play it.It is always fun to watch the crowds reaction to Casper.
