when the cart is turned to the laft the steering wheel pops, and dont turn as far to left as the right
is there adjustment on steering box or anything to do?
I'm not a cart expert but my experience with auto steering gears tell me they are adjustable but the adjustment usually takes play out equally on both sides so I don't think that's your solution. I'd look at tie rod ends and king pins and if there's no play there it's possible that there's a problem with the steering gear itself.
thee are adjustments on tie rods but you should have a manual to help you thur it cause you can really throw the front end out of wack if you just start adjusting............................
