I NEED HELP. I HAVE A 2000 CLUB CAR VILLAGER 6. 350 CC RUN ALL THE TIME MOTOR. AFTER YOU START THE MOTOR HIT THE THROTTLE AND THE ENGINE DIES. RUN ALL THE TEST IN THE SHOP MANUAL AND STILL HAVE PROBLEM. I CHANGED THE MICROSWITCH ON THROTTLE STILL SAME PROBLEM. I UNPLUGED RPM LIMITER AND EVERYTHING WORKS CORRECTLY BUT WILL NOT DIE WHEN KEY IS TURNED OFF. SO I CHANGED RMP LIMITER AND THE SAME PROBLEM IS STILL THERE. ANY SUGGESTION ?????????? THANK YOU
