Have a 2000 48 v D S I suspect the internal wiring or resistors are not correctly installed,if anyone has a schematic of this unit it would be much appreciated.
Thanks in advance Mike
The V-Glide has 9 posts and starting from the bottom-
#1 has the yellow wire
#2 has the purple wire
#9 has the black/white wire
Resistors are attached as follows
between #2 - #3 0 ohm (one black band)
#3 - #4 910 ohm (white,brown and gold)
#4 - #5 750 ohm (violet,green,brown and gold)
#5 - #6 910 ohm
#6 - #7 1000 ohm (brown,black,red and gold)
#7 - #8 1000 ohm
#8 - #9 1000 ohm
