New to forum as member but have researched many threads and have not seen the answer to this question. Replaced CDI box due to NO Spark (after replacing coil) and noticed the white wire and the red wire coming from the ignition coil and connecting to the 4-pin plug from the CDI box did not match up with the same color (white and red) wires. The red wire from the solenoid connects to the white wire going to the coil and the white wire from the CDI box connects to the red wire to the coil. Are my wires reversed? I have white wire to Negative side of coil getting battery voltage when cranking which means the red wire on Positive side of coil should be pulsing. Is this correct? Thanks in advance for any comments/help. PS.--The wires from pulsar to the 4-pin connector match up with the wires from the CDI box. (Black to Black--Red/White to Red/White)
