Redjeeper
Help I took the key switch out of my cart to try and wire in some lights. I used a test light and I think I accidentally touched two leads on the key switch as I saw a small spark now the car won’t run at all I’ve replaced the solenoid it clicks. I checked the voltage at the solenoid, the battery side of the solenoid reads pack voltage the controller side of the solenoid with the toe run switch in tow maintenance mode I have .5 voltage drop. If I remove the resistor, the controller side of the solenoid slowly drops to zero. I’m at a loss any help would be certainly appreciated. Thank you.
