Hello All,
I am a newbie here to this site. Looks like a great place to visit and get help.
I have this 2000 model Club Car, I think called a 48 volt series type. It does not have the "tow and run" switch or rocker switch for forward and reverse.
Last week it got slower and slower for about a hundred yards and quit. I checked just about eveything I knew to check, batteries, solonoid, wire tightness, etc. and still no go.
I opened the accelerator switch box, with batteries disconnected, and held a small amount of pressure on the swinging arm, that regulates the "speed" of the cart, reconnected the batteries and it started running again. Only thing, it runs wide open all the time. No matter where the pedal is positioned. The only thing I did was clean the brass connections with fine grit emery cloth and wipe clean.
Any ideas?
Is it the controll box done went bad, stuck in the max position?
Any suggestions on test I can do to pin point the problem?
Any place I can send the controll box to get it tested and refurbished if need be? A tag on it says it is a refurbished unit.
Thanks and Have a Great Day,
Any ideas?
