How do you check conpresstion on a two stroke
E ez chris New Member Mar 15, 2009 #2 remove spark plug. insert said gauge in spark plug hole. ground plug wire to frame. MAKE VERY SURE NO FUEL LEAKS!!! crank engine at least 6 or 7 times observe gauge. think that should do it.
J jersey New Member Mar 16, 2009 #3 Thank you I did not know if there was something special to do on a two strok
