1st TIMER
PAT419
I HAVE A 1984 EZGO WHAT,S HAPPEN IS I HAVE TO PUT THE GO PEDAL ABOUT 1/4 THE WAY DOWN
TO GET IT TO MOVE BUT IT TAKES OFF LIKE A TOP FUEL DRAGSTER IT LIKE IT HAS NO 1ST GEAR AFTER
IT GETS ROLLING IT OK TILL I HAVE TO HIT THE PEDAL AND ITS HANG ON ALL OVER. ANY IN
FOR WILL HELP
AS I AM LOST AT THIS
IT IS A COIL CART
THANK YOU
thewiseone71
I got one doing the same thing, and am looking for wiring diagram. it has one solenoid , i put new bats in it and when I hooked the last one up...it took off on its own.....something is shorted in the solenoid or something?
rhgc
wiseone, Ive had then do that to me too....always a pucker factor when the cart takes off by itself
divot61
thats never happened to me but i sure would like to see the vid on that, hope no one got hurt. with fresh batts in it that would be quite the chase
BadToTheBone
Moderator
It could be a problem with the pot box. You can find instructions on the forum for checking it. Are any of the resistor coils broken? Are all the connections good at the resistor coils?
