preceptguy
Hi and thanks to all for the forum and sharing your expertise,
I have a 98 EZGO Freedom that I believe is a TXT - F/W switch below seat, no run/tow switch on controller.
The motor was replaced 1.5-2 years ago and upgraded to a Raptor. The controller was also upgraded to handle the larger motor around the same time. I just replaced all batteries 2 weeks ago and cart has been running fine (and fast).
I did notice in the last few months that the cart would sometimes "lurch" a little on initial depression of the accelerator pedal, but that was very infrequent. It also had an issue "engaging" when I put it in reverse about a week ago and it took several times moving the switch back and forth before it kicked in.
Yesterday, in the middle of the 18th fairway, it made the lurch as I went to go, then nothing.
The "beeper" sounds when put in reverse, and the solenoid clicks when pedal depressed in both forward and reverse. Batteries when fatality occured were still showing 90% charge.
Can find no loose connections and cart was running great for 2 weeks after battery install.
Any ideas appreciated and am not a genius with a multitester so may need very detailed instructions for that.
