1998 EZGO TXT Turns Over But Won't Start
Tomcat
1998 EZGO TXT turns over, won’t start, low compression at 80psi. Valves adjusted to .006. Good spark, clean carb. Any suggestions? I’m a novice here, HELP!
When you checked the compression did you hold the throttle opened. If not test it again while holding the throttle wide open. Welcome to Cartaholics. :hattip:
